Administrators frédogoto Posté(e) 29 mai 2013 Administrators Signaler Share Posté(e) 29 mai 2013 on connais tous ces boutique qui propose de APN refroidi et modifiéla y'en a un qui pousse assez loin le raffinement :ils proposent un 1100D, 2 étage pelletier (-80°c), couleur (1200$) ou monochrome (1400 $)12 mega pixel et pixel de 5.2µm USBil proposent de telecharger les dark a 6400 ISO30s, 60 180 300 6000, 1800 et 3600s (ce dernier lien ne marche pas chez moi)http://www.jtwastronomy.com/products/UltimateDarks/30-6400.ziphttp://www.jtwastronomy.com/products/UltimateDarks/60-6400.ziphttp://www.jtwastronomy.com/products/UltimateDarks/180-6400.ziphttp://www.jtwastronomy.com/products/UltimateDarks/300-6400.ziphttp://www.jtwastronomy.com/products/UltimateDarks/600-6400.ziphttp://www.jtwastronomy.com/products/UltimateDarks/1800-6400.ziphttp://www.jtwastronomy.com/products/UltimateDarks/3600-6400.zipils dévellopent un argumentaire intéréssantThe limiting factor with DSLRs has always been noise and low QE (quantum efficiency a.k.a sensitivity), these factors are now myths with our camera. Let us explain - In normal operation a DSLR sensor can reach 50°C within an hour, resulting in catastrophic noise levels and unusable data. Talk of temperatures in DSLRs leads to confusion when comparing various systems. Often the quoted delta T refers to the temperature below ambient, despite the fact that the sensor itself could be as much as 30°C higher than ambient temperature. At room temperature our system will cool to -30°C, this is a delta T (ambient) of -50°C, but a delta T (sensor) of -80°C. At this temperature, almost all the remaining noise in the system is off-sensor. As our dark frames will confirm, our cameras have practically constant noise, from 30 seconds to 1 hour. This is ground breaking, and proves without a shadow of a doubt that we have all but completely eliminated the major source of noise in a DSLR based system.que je traduirais par Le facteur limitant des reflex numériques a toujours été de bruit et de rendement quantique, ces facteurs sont désormais "mythes"*avec notre caméra. Expliquons-nous - En fonctionnement normal, un capteur DSLR peut atteindre 50 ° C en une heure, ce qui entraîne des niveaux de bruit catastrophiques et les données inutilisables. Parlez des températures dans les reflex numériques conduit à la confusion lorsque l'on compare les différents systèmes. Souvent, la cité delta T désigne la température sous la température ambiante, malgré le fait que le capteur lui-même pourrait être jusqu'à 30 ° C supérieure à la température ambiante. A température ambiante, notre système se refroidit à -30 ° C, c'est un delta T (température ambiante) de -50 ° C, mais un delta T (capteur) de -80 ° C. A cette température, presque tout le bruit restant dans le système est hors capteur (bruit electronique). Comme nos dark le confirment, nos caméras ont bruit pratiquement constant, de 30 secondes à 1 heure. c'est clair et prouve sans l'ombre d'un doute que nous avons complètement éliminé la principale source de bruit dans les APN.*les auteurs sous entendent assez malhonnêtement que leur produit fait "disparaître" ces soucisnon il ne les fait pas disparaître mais il en réduisent l'impact les auteurs oublient la encore d'autre source que le buit thermique / electronique : le bruit photonique pour lequel on ne peut absolument rienen outre le Q.E n'est pas défini par le bruit thermique (enfin il me semble, fifi me corrigera sans vergogne si je me trompe)ensuite vien un argument sur la sensiblité et ils nous indiquent avoir une sensibilité réele proche de 40-50% (comprendre 40% )le reste de l'argumentaire est exposé icion peut pas se plaindre qu'ils ne soient pas prolixe : http://www.jtwastronomy.com/products/ultimate.phpmalgré certain argument de mauvaise fois, le reste tombe sous de sens : notament les question relative a l'ergonomie infiniment supérieure de ce systeme contre le CCD, surtout au niveau pilotage !enfin petit plaiz qui ne gache rien, on peut choiri la couleur ! c'est cool car je me voyais mal introduire du rose dans ma chaîne optique Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Administrators frédogoto Posté(e) 29 mai 2013 Auteur Administrators Signaler Share Posté(e) 29 mai 2013 hummm je vien de voir que le bidule consomme 70w !!!!!!!!!!!!!!!!!!!!!ce qui rend son utilisation en nomade plutôt pénible voir impossible car cet apn ce pilote 100% par Pc, contrairement au APN classiques, il faut donc ajouter la consommation pc, résistance chauffante monture ccd de guidage...hummmmmm Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Avexiens peppuccio Posté(e) 29 mai 2013 Avexiens Signaler Share Posté(e) 29 mai 2013 Il me semble qu'on en avait déjà parlé, mais à ce niveau pourquoi ne pas prendre une CCD? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Administrators frédogoto Posté(e) 29 mai 2013 Auteur Administrators Signaler Share Posté(e) 29 mai 2013 ben je vois deux raisons :un c'est nettement moin cherdeux c'est bcp plus ergonomique (liveview, rapidité) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Administrators frédogoto Posté(e) 2 juillet 2013 Auteur Administrators Signaler Share Posté(e) 2 juillet 2013 hello.bientot une v2 en préparation Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Avexiens peppuccio Posté(e) 2 juillet 2013 Avexiens Signaler Share Posté(e) 2 juillet 2013 quand je regarde le bazar je ne vois pas où est le liveview Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Administrators frédogoto Posté(e) 2 juillet 2013 Auteur Administrators Signaler Share Posté(e) 2 juillet 2013 sur le pc... O:-) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Avexiens peppuccio Posté(e) 3 juillet 2013 Avexiens Signaler Share Posté(e) 3 juillet 2013 bof bof Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
