Atik One Combo
Obiwan
salut les gars.
Lors de la réunion d'hier, Frédo à parler de la nouvelle Atik One,
La voici en version combo avec :
- atik One 6.0
- atik Gp Guider
- atik OAG
L'atik One :
Sensor Type: CCD - Sony ICX694
Horizontal Resolution: 2750 pixels
Vertical Resolution: 2200 pixels
Pixel Size: 4.54 µM x 4.54 µM
ADC: 16 bit
Readout Noise: 5e- typical value
Interface: USB 2.0 High Speed, with embedded hub
Power: 12v DC 2A
Maximum Exposure Length: Unlimited
Minimum Exposure Length: 1/1000 s
Cooling: Termoelectric set point with max ΔT=-38°C
Weight: approx. 900 gr
Backfocus: ~27mm
Gros avantage; un port USB pour la caméra de guidage et une alim supplémentraire.
La caméra de guidage est ultra petite :
Sensor Type: Sony ICX445 EXview HAD ii CCD
Horizontal Resolution: 1296 pixels
Vertical Resolution: 964 pixels
Pixel Size: 3.75 µM x 3.75 µM
ADC: 12 bit
Frame rate: 30 fps max
Interface: USB 2.0 High speed
Power: USB powered
Cooling: Passive
Weight: ~80g
Backfocus: ~7mm
The 5 position integrated filter wheel features a mechanical roller for filter location ensuring the highest levels of reproducibility image after image. The filter wheel is natively controlled from our software or has an Ascom driver for 3rd party programs. To make filter changing less of a chore the camera comes with a tool to allow filters to be loaded without opening the camera.
