Posté(e) 21 octobre 201113 a Administrators ENFIN un truc intelligent pour réduire la filasse : je vous laisse juge :£198.00 soi en 228€HiTec Astro Mount Hub Pro V2The mount Hub Pro is the answer to many observatory or mobile power requirements.In addition to the below functionality the new Mount Hub pro now also includes a 5 Port USB HubIn one small neat and tidy unit you can do the followingControl via a PC and the included softwareControl & Power Up to 4 Dew Heater BandsPower CCD Cameras and autoguidersPower motorised Filter WheelsPower a Flatfield PanelPower a Robo Focus or Moonlite Compatible motor focuser and control via the included ASCOM softwarePower most popular telescope mountsPower many other peripheral devicesIn manual mode where no PC is necessary you canPower up to 4 Dew BandsPower a Robofocus or Moonlite compatible motor focuser with the optional manual hand controlThe Mount hub Pro draws it's power from one Mains to 13.8v supply (not supplied) and allows you to neatly and easily power nearly all observatory peripherals.The MHP is an integrated device consisting of• 8 Individually selected power outlets.• 4 Controllable ‘Dew Heater’ Outputs.• A focus controller capable of driving any unipolar stepper motor basedfocuser.• A USB connection which enables the above to be controlled from any PCusing Windows XP, Windows Vista. Windows 7A driver has been developed which will allow the focus controller to operate with any ASCOM compliant software such as Maxim DL, CCD Auto Pilot,or the excellent (and free) Focus Max.
Posté(e) 21 octobre 201113 a Génial. Y'en a qui on été plus loin que les BRA2 qu'on a mis au point avec Brice. http://www.hitecastro.co.uk/index.php?option=com_content&view=article&id=48:mount-hub-pro&catid=36:mount-hub-pro&Itemid=54
Posté(e) 21 octobre 201113 a Ouaouh !Qui le premier va oser tester ? C'est sûr que sur le papier ça parait intéressant, mais le tout en un je ne sais pas, si ça plante tu plante tout ! Et est ce que focusmax fonctionne à travers ce truc ?
Posté(e) 21 octobre 201113 a Auteur Administrators oui....c'est indiqué dans les fonctionnalités..mon expérience : moin tu as de bordel, fils, boiter, moi tu as de risque que ça plante....
Posté(e) 21 octobre 201113 a Avexiens Génial. yapuka acheter et tester...Je vais déjà regarder de près les caractéristiques.
Posté(e) 21 octobre 201113 a pour moi, il manque un truc important : un port com (en plus) utilisable en ascom pour la commande de décalage entre les poses puisque de nombreux logiciels finissent par planter quand on utilise un Canon EOS : Maxim DL fini par planter, guidemaster aussi, et phg n'a pas de link avec DPP ou autre logiciel de prise de vue pour APN.C'est le seul regret.maintenant, c'est vrai que j'utilise bcp la CCD, alors ...Je comprend pas pk ils parlent de 13.8V alors qu'on voit bien une prise allume cigare (donc 12V) : The Mount hub Pro is powered by a Mains to 13.8v supply, available as an optional extra.(http://www.widescreen-centre.co.uk/Products/Mount_Hub_Pro.html)Vous avez vu la grosseur du boitier ?
Posté(e) 21 octobre 201113 a intéressant Mon alim qui alimente tout le matos sort 13.8V. Je préfère nettement aux classiques 12V. Cela permet de reproduire une batterie voiture et surtout de limiter le risque de chute de tension en dessous de 12V qui est néfaste pour certains appareils (monture, caméra...). Avec 13.8V, il faut vraiment tirer sur l'alim pour la faire descendre a 12V.
Posté(e) 21 octobre 201113 a Certe une batterie est souvent au-dessus de 13V mais il arrive parfois qu'en fin de séance voir en plein milieu de nuit, la tension chute et se retrouve à 12V voir presque en dessous et là ça peut effectivement être la cacatastrophe. Ouille ouille ouille pour les moteurs de l'EQ6 qui n'ont plus assez de jus. Je dis ça car avec mon ancienne batterie de m...e j'ai eu pas mal de soucis.
Posté(e) 22 octobre 201113 a Fredo, tu le possédes? vu que tu postes des photos en config.Combien de cable entre le PC et la monture?Merciaries51
Posté(e) 22 octobre 201113 a Auteur Administrators Non, ce sont des images isse du constructeurune sorte de Pierro Astro anglaishttp://www.hitecastro.co.uk/
Posté(e) 6 novembre 201113 a Auteur Administrators Salutje vien de passer commande chez IanKingc'est la que c'est le plus avantageuxje vous dirais de quoi il en retourne des que je le recevrais
Posté(e) 6 novembre 201113 a Coolje suis très très intéressé pour voir ce qu'il y a à l'intérieur de ce boitier.Penses-tu que c'est envisageable ?
Posté(e) 10 novembre 201113 a ayeeee je l'ai reçu ce matin, pile au moment ou je partais travailler. J'ai donc juste eu le temps de debaler mais pas d'en faire des photos.Premiere surprise : il y a des pleine port usb. Je ne sais pas trop si en plus du hub'puissance' ce truc fait aussi hubusb. Sans doute.... il va faloir que je teste cela....
Posté(e) 10 novembre 201113 a Génial !Le cordon USB rentre directement dans la boite ? Combien d'entrées ? On ne voit pas très bien en fait. Est-ce qu'il y a un logo CE quelque part sur le boîtier ?C'est quoi comme prise pour les 12 V ?On dirait qu'il y a plusieurs types de sortie 12 V ???
Posté(e) 10 novembre 201113 a Auteur Administrators Génial !Le cordon USB rentre directement dans la boite ? Combien d'entrées ? On ne voit pas très bien en fait. oui il va directement dans la boiteil y a 5 entré usbEst-ce qu'il y a un logo CE quelque part sur le boîtier ?non, juste un hologramme sceau de garantieC'est quoi comme prise pour les 12 V ?il y a des RCA (x4) et 11 prise femele "gros jack" mais je crois que le jack de ma cam n'y rentre pas... faut que je vérifie On dirait qu'il y a plusieurs types de sortie 12 V ???ben rca et jack
Posté(e) 11 novembre 201113 a Cela t'est revenu à combien ? C'est quoi des prises rca ?Quand tu auras tout installé et branché, pourrais-tu faire un petit schéma des branchements ?Merci.aries51
Posté(e) 11 novembre 201113 a Auteur Administrators clea m'est revenu a 240€pour le schéma : c'est assez simple. ci dessous le schéma de mon installation actuelle (simplifié car il n'y a pas les truc de puissance comme les alimentations électrique et les résistance chauffantepour simplifier ce boitier vers remplacer le mini pc qui va sur mon setup mobile (non représenté sur ce schéma)http://img4.hostingpics.net/pics/3237952000.png
Posté(e) 11 novembre 201113 a Auteur Administrators pour alban : la distribe USBet la le pack livré complet :
Posté(e) 11 novembre 201113 a Auteur Administrators après installation :c'est rogolo, en entend les relais s'actioner quand on met en route les différente unité de puissance
Posté(e) 12 novembre 201113 a Auteur Administrators oui, c'est bien de l'USB2; je vais l'essayer cet apres midi avec la SIGMA, car j'ai des doutes sur le mode asynchrone
Posté(e) 12 novembre 201113 a Salut Frédo, le fusible dans la fiche allume cigare est-il un 10A, plus ou moins ?Tu devrais vérifier ça avant de brancher toute ton installation.Pour la norme CE c'est un peu embêtant car si il t'arrive quelque chose avec ce boitier, ils sont dans la m.... car pas couvert.Normalement, on a pas le droit de vendre un produit électronique sans qu'il est était testé et validé par un organisme certifié.Mais bon, ça devrait pas arriver, à moins que tu te serve de ça les pieds dans l'eau !
Posté(e) 12 novembre 201113 a Auteur Administrators Salut Frédo, le fusible dans la fiche allume cigare est-il un 10A, plus ou moins ?je ne sais pas.. mais vue qu'a chaque fois que j'ai démonté une prise allume cigare , des ressorts mon pété à la gueule, je ne préfère pas démonter Tu devrais vérifier ça avant de brancher toute ton installation.je ferai des test cet apremidi je verrais bien mais je ne suis pas inquiet : je suis a 6A max Pour la norme CE c'est un peu embêtant car si il t'arrive quelque chose avec ce boitier, ils sont dans la m.... car pas couvert.Normalement, on a pas le droit de vendre un produit électronique sans qu'il est était testé et validé par un organisme certifié.Mais bon, ça devrait pas arriver, à moins que tu te serve de ça les pieds dans l'eau !tu devrait dire ça a celestron, pierro astro, meade etc...y'a pas de CE dessus...
Posté(e) 12 novembre 201113 a Auteur Administrators premiers test, premier résultats : c'est juste d'enfer. génialun peut de bricolage quand meme pour adapter mes prise de puissance mais ça marche au poil.pis j'ai plus de chute de tension quand je met le peletier a fond )la sigma fonction pas mais la dmk a fond, y'a également un adaptateur usb - serial , tout est reconnu et fonctionnel..peut pas mieux direpis niveau filasse ben c'est quand mem plus reposantdu coût je branche directement tout ce bazard en live sur mon pc portable via un prise USB et le mini pc je l'ai enlevé : il va finir sur la fsq en mode setup de voyagepour le remote, quel bonheur !!!!je le recommande chaudement
Posté(e) 25 juin 201213 a Salut FrédoFinalement, es-tu content du HiTecAstro ?Je vais en commander 1 MerciPhilippe
Posté(e) 25 juin 201213 a Auteur Administrators je suis pleinement satisfait du produitj'adore le fait qu'il y ai le module de commande du focuseur en plus du resteil y a des chose a savoir avec ce produit1. la première c'est que le pilote Ascom du focuseur du MHP n'a pas été écris pour des version non anglaise de windows. au début j'a galéré a comprendre ce qui ce passait, mais par élimination essais / erreur et courriel avec l'auteur nous avons pu établir ce qui se passait et installer les drivers a la main dans le répertoire ascom français qui va bien. pas de soucis pour les autres fonctionnalités2 il n'y a pas de sonde de température sur la MAP : dommage !!! j'ai cuisiné l'auteur pour qu'il prenne en charge via son logiciel une sonde USB de température : il a répondu : pas con mais j'ai pas le temps en ce momentle pilotage de ce truc et simple intuitif et fonctionnel. je regrette que son soft ne gère pas des "profils" mais cela viendra peut êtrej’apprécie le nombre très élevé de sortie 12V, les prises USB. mais j'airais souhaité qu'il propose au moins deux ports séries : dommagecomme tout les HUB usb, ce hub ne gère pas le mode isochrone de certaines CCD, comme la miene par exemple (Sigma) la le type ne peut rien y fairede temps en temps le MHP n'est pas vu par le PC et la déconnexion reconnexion n'y change rien, toute fois le HUB USB continue de fonctionner tel quel et si qui était activé continue d'etre actif. donc pas gênant dans l'absolue, mais on ne peut pas changer d'etat : allumer ou éteindre un truc ou changer la valeur de chauffage des résistance chauffante. pour ces dernier y'a possibilité de les piloter a la main par trois portardQuand cette non réponse du MHP se produit (en général suite a un plantage du pc) il suffit de le dés-alimenter électriquement et de déconnecter le port usb (de façon a vider tous les condensateurs)puis 15- 20 seconde plus tard le rebranchera mon sens il manque une sonde GPSalors vue comme ça , ca fait négatif alor qu'en fait je suis hyper content de cet engin,j'ai un bon recule dessus maintenant, et si c’était a refaire, c'est sans hésitation que le referais
Posté(e) 3 juillet 201411 a BonjourFredogoto je possède ce MontHubPro et je viens d'installer un moteur pas a pas de focalisation (robofocus)Comme toi le driver n'est pas reconnu.Peux tu nous indiquer (au cas ou on serait plusieurs) la manip a faire pour poser le driver dans le bon répertore.Ce serait sympa.Merci de ton aide.A+Régis.
Posté(e) 3 juillet 201411 a Auteur Administrators je te donne la reponse en english je te traduit cela ce soirthe pb was : i'd copy dll in the wrong folder ;C:\Program Files\Common Files\ASCOM\Focuserbut the good folder is in french C:\Program Files\Fichiers communs\ASCOM\Focuseris this sentence made me understand the problem My best advice is to ensure that the HIDLibrary.dll and MHP.dll are in the same directory
