Posté(e) 9 mai 20169 a Avexiens Comme ma lunette me donne des étoiles multicolores, je me console en traitant les champs larges capturés avec la Star Adventure.Objectif 70mm ouvert à f3.5, 16 poses de 88 secondes autour de Deneb.Voici le détail de la reduction astrometrique de l'image => avec les catalogues locaux et ligne de commande sur le Mac.hugh⨕mopla:nebuleuse|● solve-field -O --scale-units dw -L 10 -H 40 --downsample 4 n.jpgReading input file 1 of 1: "n.jpg"...jpegtopnm: WRITING PPM FILERead file stdin: 5166 x 3420 pixels x 1 color(s); maxval 255Using 8-bit outputExtracting sources...Downsampling by 4...simplexy: found 1940 sources.Solving...Reading file "./n.axy"...Field 1 did not solve (index index-4119.fits, field objects 1-10).Field 1 did not solve (index index-4118.fits, field objects 1-10).Field 1 did not solve (index index-4117.fits, field objects 1-10). log-odds ratio 134.2 (1.91642e+58), 21 match, 0 conflict, 54 distractors, 31 index. RA,Dec = (310.146,46.0193), pixel scale 12.164 arcsec/pix. Hit/miss: Hit/miss: +++-++-+-+--+-+-+--+----+-----++-+--+-+----+----------+------------+------+(best)-------------------------Field 1: solved with index index-4116.fits.Field 1 solved: writing to file ./n.solved to indicate this.Field: n.jpgField center: (RA,Dec) = (310.1, 46.02) deg.Field center: (RA H:M:S, Dec D:M:S) = (20:40:34.680, +46:01:01.552).Field size: 17.3492 x 11.5265 degreesField rotation angle: up is 87.8024 degrees E of NCreating new FITS file "./n.new"...Creating index object overlay plot...Creating annotation plot...Your field contains: Part of the constellation Cygnus (Cyg) The star 30Cyg The star 31Cyg The star 32Cyg The star 34Cyg The star 36Cyg The star Sadr (γCyg) The star 40Cyg The star 43Cyg The star ω1Cyg The star ω2Cyg The star Deneb (αCyg) The star 51Cyg The star 55Cyg The star 56Cyg The star 57Cyg The star νCyg The star 59Cyg The star 60Cyg The star ξCyg The star 61Cyg The star 63Cyg IC 1318 / gamma Cyg nebula IC 5068 IC 5070 / Pelican nebula NGC 6997 NGC 7000 / North America nebula NGC 7039La full est ici: http://www.astrobin.com/full/248251/
Posté(e) 9 mai 20169 a Administrators ha c'est très sympas... on peu voir la full qque part ?ps. y'a des étoiles qui me paraissent anormalement jaune
Posté(e) 9 mai 20169 a trés joli résultat, par contre je trouve aussi que beaucoup d'étoiles sont très jaunes... une petite crrection colorimétrique et elle sera superbe ;-)
Posté(e) 10 mai 20169 a Avexiens C'est bizarre car le bleu semble bien présent et le rouge aussi, mais effectivement les étoiles aussi jaunes ce n'est pas en ligne avec le champ en question.
Posté(e) 10 mai 20169 a Auteur Avexiens Il y a quelque chose qui cloche la dedans, j'y retourne immédiatement !
Posté(e) 11 mai 20169 a Auteur Avexiens ah ? => Boris Vian - La java des bombes atomiques.Bon, j'ai largement baissé la saturation des jaunes dans la nouvelle version. Les nebulosités sortent un peu plus rouge aussi.c'est dommage car j'aimais bien ce coté orangé, mais les étoiles sont aussi plus naturelles. Toujours sur astrobin les full.
Posté(e) 13 mai 20169 a Membres du bureau SalutTrès réussi ce grand champ, j'aime bcp (préférence pour la seconde version).
Posté(e) 13 mai 20169 a Avexiens Comme Xavier : j'aime beaucoup ce champ et la seconde version est mieux.
