Posté(e) 18 février 201412 a bonjourQuelqu'un aurait-il des infos sur la date de sortie de Maximdl v6 ?Merciaries51
Posté(e) 18 février 201412 a Avexiens non aucunemais, mais, ça fait plusieurs moi qu'aucune MAJ de maximdl est sortie, ce qui veux probablement dire que la v6 est dans le pipenote admin : sujet déplacé dans la rubrique logiciel
Posté(e) 18 février 201412 a Avexiens http://www.cloudynights.com/ubbthreads/showflat.php/Cat/0/Number/6259419/Main/6258404
Posté(e) 19 février 201412 a Avexiens les fonctionnalités envisagé pour la v6Features listed:This is a *preliminary* summary of V6 feature improvements:Quick Color- See Raw RGB Bayer-encoded images in color instead of monochrome- Uses nearest-neighbour decode for speed- Does not degrade dark subtraction, etc., since image is not actually modified- User must still perform Convert Color prior to image processing and foroptimum qualityNarrowband image blending tool- Stack arbitrary number of images planes- Choose wavelength match for each filter band- Can insert same filter multiple times for multiple wavelength blendingMajor upgrade to Photometry command- Group-based analysis similar to Stack tool- Multispectral analysis- Unlimited input files- Reject images based on quality- Astrometric or auto star match star identificationSupport for PinPoint V6- Astrometry.net integration for all-sky solving- UCAC4 support- Hot pixel detection and removal for more robust solving- Improved point-spread function fitter- Deprecated support for obsolete catalogs GSC (non-corrected) and USNO SA 2.0- Now "modeless", allowing the PinPoint dialog box to remain open whenswitching images, using other commands, etc.ASCOM Switch control- Control hardware switches such as power, lights, reboot equipment, etc.Observatory webcam integration- Live view of inside of observatory via webcam- Switch control panel (handy for operating lights etc.)Built-in Davis weather station support- Display current weather status- Add weather information to image FITS headersBuilt-in Boltwood Cloud Sensor support- Display current weather status- Add weather information to image FITS headersAutomated equipment shutdown capability- Triggers include:- Sunrise- Civil, nautical, or astronomical twilight- Target low- Loss of autoguiding (clouds etc.)- Cloud sensor warning- Perform shutdown sequence:- Shutdown cameras- Park telescope- Park and close domeMulti-star autoguiding- Average measurements of multiple stars to reduce effect of seeingSupport for SBIG Differential Guider accessory- Flexure-free autoguiding with separate guide scopeSingle or dual axis dither operation- Avoid triggering mount stiction cyclesAutomatic script execution on Expose command- Option to save image prior to modifications or after modifications- Handy for running "quick look" filters on faint images, etc.Automatic pointing refinement using PinPoint- Takes pointing exposure to verify telescope position- Resynchronizes automatically- Centers target preciselyAutomated pier flipping- Detect telescope approaching limit- Pause imaging sequence- Flip telescope over pier- Automatic pointing refinement- Relocate guide star- Continue image sequenceBookmark locations on the sky- Right Ascension and Declination- Rotator angle- Save current telescope position- Load current solved position- Goto bookmark- Load and save bookmarksUser can hide unused Observatory Window tabs- Only see tabs for equipment that you are actually usingSimulated Telescope Park- Slew telescope to park position- Turn off sidereal trackingASCOM device threading- All telescope, dome, focuser, and rotator interfaces are now fully threaded- Keeps the user interface more responsive- Prevents user interface lockup if device driver locks upEnhanced camera interfaces- Camera downloads are now threaded- Eliminates user interface delays during downloadMore image processing filter options- Save fit profiles in Flatten Background- Gaussian Blur option added Unsharp Mask and Digital DevelopmentRedesigned Calibration Wizard for quick and easy calibration frame setupMany other minor enhancements and "under-the-hood" improvementsDoug---------------------------En gros une grosse partie des manques qui on inspiré le logiciel de FELOPAUL (MaxPilot) sont désormais comblés.
Posté(e) 19 février 201412 a Oui, j'ai aussi trouvé ça avec google. La sortie de la v6 est normalement prévue en février 2014, donc trés bientôt semble t-il.On verra bien...aries51
