bonjour
Quelqu'un aurait-il des infos sur la date de sortie de Maximdl v6 ?
aries51
Merci pour la réponse. On dirait que le secret est bien gardé !
aries51
les fonctionnalités envisagé pour la v6
Features listed:
This is a *preliminary* summary of V6 feature improvements:
Quick Color
- See Raw RGB Bayer-encoded images in color instead of monochrome
- Uses nearest-neighbour decode for speed
- Does not degrade dark subtraction, etc., since image is not actually modified
- User must still perform Convert Color prior to image processing and for
optimum quality
Narrowband image blending tool
- Stack arbitrary number of images planes
- Choose wavelength match for each filter band
- Can insert same filter multiple times for multiple wavelength blending
Major upgrade to Photometry command
- Group-based analysis similar to Stack tool
- Multispectral analysis
- Unlimited input files
- Reject images based on quality
- Astrometric or auto star match star identification
Support for PinPoint V6
- Astrometry.net integration for all-sky solving
- UCAC4 support
- Hot pixel detection and removal for more robust solving
- Improved point-spread function fitter
- Deprecated support for obsolete catalogs GSC (non-corrected) and USNO SA 2.0
- Now "modeless", allowing the PinPoint dialog box to remain open when
switching images, using other commands, etc.
ASCOM Switch control
- Control hardware switches such as power, lights, reboot equipment, etc.
Observatory webcam integration
- Live view of inside of observatory via webcam
- Switch control panel (handy for operating lights etc.)
Built-in Davis weather station support
- Display current weather status
- Add weather information to image FITS headers
Built-in Boltwood Cloud Sensor support
Automated equipment shutdown capability
- Triggers include:
- Sunrise
- Civil, nautical, or astronomical twilight
- Target low
- Loss of autoguiding (clouds etc.)
- Cloud sensor warning
- Perform shutdown sequence:
- Shutdown cameras
- Park telescope
- Park and close dome
Multi-star autoguiding
- Average measurements of multiple stars to reduce effect of seeing
Support for SBIG Differential Guider accessory
- Flexure-free autoguiding with separate guide scope
Single or dual axis dither operation
- Avoid triggering mount stiction cycles
Automatic script execution on Expose command
- Option to save image prior to modifications or after modifications
- Handy for running "quick look" filters on faint images, etc.
Automatic pointing refinement using PinPoint
- Takes pointing exposure to verify telescope position
- Resynchronizes automatically
- Centers target precisely
Automated pier flipping
- Detect telescope approaching limit
- Pause imaging sequence
- Flip telescope over pier
- Automatic pointing refinement
- Relocate guide star
- Continue image sequence
Bookmark locations on the sky
- Right Ascension and Declination
- Rotator angle
- Save current telescope position
- Load current solved position
- Goto bookmark
- Load and save bookmarks
User can hide unused Observatory Window tabs
- Only see tabs for equipment that you are actually using
Simulated Telescope Park
- Slew telescope to park position
- Turn off sidereal tracking
ASCOM device threading
- All telescope, dome, focuser, and rotator interfaces are now fully threaded
- Keeps the user interface more responsive
- Prevents user interface lockup if device driver locks up
Enhanced camera interfaces
- Camera downloads are now threaded
- Eliminates user interface delays during download
More image processing filter options
- Save fit profiles in Flatten Background
- Gaussian Blur option added Unsharp Mask and Digital Development
Redesigned Calibration Wizard for quick and easy calibration frame setup
Many other minor enhancements and "under-the-hood" improvements
Doug
En gros une grosse partie des manques qui on inspiré le logiciel de FELOPAUL (MaxPilot) sont désormais comblés.
Oui, j'ai aussi trouvé ça avec google. La sortie de la v6 est normalement prévue en février 2014, donc trés bientôt semble t-il.
On verra bien...
aries51
