Nebulosity V2 gère le dithering pour PHDGuiging
Salut.
De mémoire, nebuloIty gère les séquences dans un onglet spécifique.
Non désolé j'ai confondu avec MaximDL ou Prism que je n'ai plus car j'ai dépassé la période d'essai.
en tout cas, pour la liaison avec PHD, il faut lire la section view help et lire à la page 17 :
4.5.4 Link to PHD Guiding
PHD Guiding is the popular freeware guiding package by Stark Labs. With it, guiding can be as
simple as “Push Here Dummy.” With the PHD Guiding dialog, you can establish a link to PHD
Guiding so that the two packages can talk to each other. This gives you two powerful features.
First, it lets you pause guiding during the download of your main image. Some cameras are
sensitive to interruptions on the USB bus and if the guide camera shares the USB bus, the image
quality can be degraded. The “Pause during download” option will let you enable this feature.
The second feature is to enable “dithering” of the image’s location across frames. Between
frames, Nebulosity can send a signal to PHD to tell it to move the “lock position” (the position of
the crosshairs in PHD) by a small, random amount. Once PHD has moved the star and reestablished
stable guiding in the new location, a signal is sent to Nebulosity to let it know it can
continue with the next frame in the series.
To do this, you must:
1. Have PHD 1.8.6 or later running and tell it to “Enable Server” in the Tools menu (PHD
will remember if you last left the server on and restart it the next time you start PHD). If
Windows asks you whether it’s OK to do this, tell it yes.
2. In Nebulosity’s PHD Guiding dialog, click on the “Connect” button.
3. In the dialog, tell it how much “dither” to send. The dither sent will be a random number
of pixels in X and Y, scaled by the level you pull down here. In the lowest level, the
random numbers will vary from -0.5 to 0.5 pixels and in the highest they will vary from
-1.5 to 1.5 pixels in the guide frame. Since people typically guide at shorter focal lengths
than they image at, this will usually have a much larger effect in your main images.
4. It may be worth changing the “Settle threshold”. This specifies how far off the star can be
from the lock position before PHD sends the message that it has gotten the star back on
target and it is OK to resume your series capture.
trop fort ce script.
Téléchargé et déjà installé.
J'ai hate de tester ça même si maintenant, j'utilise Maximdl encore pour quelques jours en version d'essai >:p
Je ne comprends pas l'anglais ou si mal, mais je crois avoir compris que le lien fourni par spoutnick propose un séquenceur pour Nebulosity (ça parle aussi d'Astroart, mais je ne sais pas pourquoi!). Si j'ai bien compris, il faut télécharger le programme, mais ensuite, où le mettre? Et comment ça fonctionne ?
Je sais bien que tout est expliqué, mais encore une fois, je suis incapable de traduire.
puisque tu l'a installé, tu devrais pouvoir m'aider si tu le veux bien.
Encore merci à spoutnick et au concepteur de ce programme, j'espère recevoir de l'aide pour pouvoir l'utiliser. Merci d'avance!
aries51 ii
La page du lien de Spoutnik ressemble furieusement à son équivalent dans Maximdl ;)Séquenceur maxim.doc
Quelqu'un a t-il essayé le séquenceur dont parle spoutnik?
aries51
J'ai installé le séquenceur pour Nebulosity, ça a l'air tip top ! Puisque le tuto qui va avec est en anglais, je ne pige pas tout, mais pour une utilisation de base, ça n'a pas l'air trés différent du séquenceur Artemis Capture. Une traduction du tuto serait la bienvenue pour exploiter à fond le séquenceur.
Pour info, quand on active sg (l'utilitaire du séquenceur), cela ouvre automatiquement Nebulosity dans une autre fenêtre, et c'est dans sg que se commande le dithering.
à+
aries51 :)
Bon aller promis je m'y colle au tuto PHD + Nébulosity.
Je commence cette semaine.
Je posterai une nouvelle rubrique dès que possible.
C'est sympa, j'attends ça avec impatience ! Merci
aries51 :)
  • 1 year later...
Il y a eu une suite ? :x
