les HUB astro Ultime ??????
ENFIN un truc intelligent pour réduire la filasse : je vous laisse juge :
£198.00 soi en 228€
HiTec Astro Mount Hub Pro V2
The mount Hub Pro is the answer to many observatory or mobile power requirements.
In addition to the below functionality the new Mount Hub pro now also includes a 5 Port USB Hub
In one small neat and tidy unit you can do the following
Control via a PC and the included software
Control & Power Up to 4 Dew Heater Bands
Power CCD Cameras and autoguiders
Power motorised Filter Wheels
Power a Flatfield Panel
Power a Robo Focus or Moonlite Compatible motor focuser and control via the included ASCOM software
Power most popular telescope mounts
Power many other peripheral devices
In manual mode where no PC is necessary you can
Power up to 4 Dew Bands
Power a Robofocus or Moonlite compatible motor focuser with the optional manual hand control
The Mount hub Pro draws it's power from one Mains to 13.8v supply (not supplied) and allows you to neatly and easily power nearly all observatory peripherals.
The MHP is an integrated device consisting of
• 8 Individually selected power outlets.
• 4 Controllable ‘Dew Heater’ Outputs.
• A focus controller capable of driving any unipolar stepper motor based
focuser.
• A USB connection which enables the above to be controlled from any PC
using Windows XP, Windows Vista. Windows 7
A driver has been developed which will allow the focus controller to operate with any ASCOM compliant software such as Maxim DL, CCD Auto Pilot,or the excellent (and free) Focus Max.
Ouaouh !
Qui le premier va oser tester ? C'est sûr que sur le papier ça parait intéressant, mais le tout en un je ne sais pas, si ça plante tu plante tout ! Et est ce que focusmax fonctionne à travers ce truc ?
Sorry,
j'avais pas lu la dernière ligne ....
Génial. yapuka acheter et tester...
Je vais déjà regarder de près les caractéristiques.
pour moi, il manque un truc important : un port com (en plus) utilisable en ascom pour la commande de décalage entre les poses puisque de nombreux logiciels finissent par planter quand on utilise un Canon EOS : Maxim DL fini par planter, guidemaster aussi, et phg n'a pas de link avec DPP ou autre logiciel de prise de vue pour APN.
C'est le seul regret.
maintenant, c'est vrai que j'utilise bcp la CCD, alors ...
Je comprend pas pk ils parlent de 13.8V alors qu'on voit bien une prise allume cigare (donc 12V) :
The Mount hub Pro is powered by a Mains to 13.8v supply, available as an optional extra.
(http://www.widescreen-centre.co.uk/Products/Mount_Hub_Pro.html)
Vous avez vu la grosseur du boitier ?
intéressant ;)
Mon alim qui alimente tout le matos sort 13.8V. Je préfère nettement aux classiques 12V. Cela permet de reproduire une batterie voiture et surtout de limiter le risque de chute de tension en dessous de 12V qui est néfaste pour certains appareils (monture, caméra...). Avec 13.8V, il faut vraiment tirer sur l'alim pour la faire descendre a 12V.
Certe une batterie est souvent au-dessus de 13V mais il arrive parfois qu'en fin de séance voir en plein milieu de nuit, la tension chute et se retrouve à 12V voir presque en dessous et là ça peut effectivement être la cacatastrophe. Ouille ouille ouille pour les moteurs de l'EQ6 qui n'ont plus assez de jus. Je dis ça car avec mon ancienne batterie de m...e j'ai eu pas mal de soucis.
Fredo, tu le possédes? vu que tu postes des photos en config.
Combien de cable entre le PC et la monture?
aries51
  • 3 weeks later...
Cool
je suis très très intéressé pour voir ce qu'il y a à l'intérieur de ce boitier.
Penses-tu que c'est envisageable ?
ayeeee
je l'ai reçu ce matin, pile au moment ou je partais travailler. J'ai donc juste eu le temps de debaler mais pas d'en faire des photos.
Premiere surprise : il y a des pleine port usb. Je ne sais pas trop si en plus du hub'puissance' ce truc fait aussi hubusb. Sans doute.... il va faloir que je teste cela....
Génial !
Le cordon USB rentre directement dans la boite ? Combien d'entrées ? On ne voit pas très bien en fait.
Est-ce qu'il y a un logo CE quelque part sur le boîtier ?
C'est quoi comme prise pour les 12 V ?
On dirait qu'il y a plusieurs types de sortie 12 V ???
Génial !
oui il va directement dans la boite
il y a 5 entré usb
non, juste un hologramme sceau de garantie
il y a des RCA (x4) et 11 prise femele "gros jack" mais je crois que le jack de ma cam n'y rentre pas... faut que je vérifie
ben rca et jack
Cela t'est revenu à combien ? C'est quoi des prises rca ?
Quand tu auras tout installé et branché, pourrais-tu faire un petit schéma des branchements ?
Merci.
aries51
clea m'est revenu a 240€
pour le schéma : c'est assez simple. ci dessous le schéma de mon installation actuelle (simplifié car il n'y a pas les truc de puissance comme les alimentations électrique et les résistance chauffante
pour simplifier ce boitier vers remplacer le mini pc qui va sur mon setup mobile (non représenté sur ce schéma)
http://img4.hostingpics.net/pics/3237952000.png
Merci Fred pour la réponse. Tu as une vraie usine à gaz !
aries51
interressant, le Hub usb il est bien USB2.0 ?
Salut Frédo, le fusible dans la fiche allume cigare est-il un 10A, plus ou moins ?
Tu devrais vérifier ça avant de brancher toute ton installation.
Pour la norme CE c'est un peu embêtant car si il t'arrive quelque chose avec ce boitier, ils sont dans la m.... car pas couvert.
Normalement, on a pas le droit de vendre un produit électronique sans qu'il est était testé et validé par un organisme certifié.
Mais bon, ça devrait pas arriver, à moins que tu te serve de ça les pieds dans l'eau !
je ne sais pas.. mais vue qu'a chaque fois que j'ai démonté une prise allume cigare , des ressorts mon pété à la gueule, je ne préfère pas démonter :}}
je ferai des test cet apremidi je verrais bien mais je ne suis pas inquiet : je suis a 6A max
tu devrait dire ça a celestron, pierro astro, meade etc...
y'a pas de CE dessus...
premiers test, premier résultats : c'est juste d'enfer. génial
un peut de bricolage quand meme pour adapter mes prise de puissance mais ça marche au poil.
pis j'ai plus de chute de tension quand je met le peletier a fond :))))
la sigma fonction pas mais la dmk a fond, y'a également un adaptateur usb - serial , tout est reconnu et fonctionnel..
peut pas mieux dire
pis niveau filasse ben c'est quand mem plus reposant
du coût je branche directement tout ce bazard en live sur mon pc portable via un prise USB et le mini pc je l'ai enlevé : il va finir sur la fsq en mode setup de voyage
pour le remote, quel bonheur !!!!
je le recommande chaudement :p
  • 7 months later...
Salut Frédo
Finalement, es-tu content du HiTecAstro ?
Je vais en commander 1
Philippe
je suis pleinement satisfait du produit
j'adore le fait qu'il y ai le module de commande du focuseur en plus du reste
il y a des chose a savoir avec ce produit
1. la première c'est que le pilote Ascom du focuseur du MHP n'a pas été écris pour des version non anglaise de windows. au début j'a galéré a comprendre ce qui ce passait, mais par élimination essais / erreur et courriel avec l'auteur nous avons pu établir ce qui se passait et installer les drivers a la main dans le répertoire ascom français qui va bien. pas de soucis pour les autres fonctionnalités
2 il n'y a pas de sonde de température sur la MAP : dommage !!! j'ai cuisiné l'auteur pour qu'il prenne en charge via son logiciel une sonde USB de température : il a répondu : pas con mais j'ai pas le temps en ce moment
le pilotage de ce truc et simple intuitif et fonctionnel. je regrette que son soft ne gère pas des "profils" mais cela viendra peut être
j’apprécie le nombre très élevé de sortie 12V, les prises USB. mais j'airais souhaité qu'il propose au moins deux ports séries : dommage
comme tout les HUB usb, ce hub ne gère pas le mode isochrone de certaines CCD, comme la miene par exemple (Sigma) la le type ne peut rien y faire
de temps en temps le MHP n'est pas vu par le PC et la déconnexion reconnexion n'y change rien, toute fois le HUB USB continue de fonctionner tel quel et si qui était activé continue d'etre actif. donc pas gênant dans l'absolue, mais on ne peut pas changer d'etat : allumer ou éteindre un truc ou changer la valeur de chauffage des résistance chauffante. pour ces dernier y'a possibilité de les piloter a la main par trois portard
Quand cette non réponse du MHP se produit (en général suite a un plantage du pc) il suffit de le dés-alimenter électriquement et de déconnecter le port usb (de façon a vider tous les condensateurs)
puis 15- 20 seconde plus tard le rebrancher
a mon sens il manque une sonde GPS
alors vue comme ça , ca fait négatif alor qu'en fait je suis hyper content de cet engin,j'ai un bon recule dessus maintenant, et si c’était a refaire, c'est sans hésitation que le referais
  • 2 years later...
Bonjour
Fredogoto je possède ce MontHubPro et je viens d'installer un moteur pas a pas de focalisation (robofocus)
Comme toi le driver n'est pas reconnu.
Peux tu nous indiquer (au cas ou on serait plusieurs) la manip a faire pour poser le driver dans le bon répertore.
Ce serait sympa.
Merci de ton aide.
Régis.
je te donne la reponse en english
je te traduit cela ce soir
the pb was : i'd copy dll in the wrong folder ;
C:\Program Files\Common Files\ASCOM\Focuser
but the good folder is in french ;)
C:\Program Files\Fichiers communs\ASCOM\Focuser
is this sentence made ​​me understand the problem
My best advice is to ensure that the HIDLibrary.dll and MHP.dll are in the same directory
