  1. frédogoto a répondu à un(e) sujet de frédogoto dans Important
    et moi je suis un con pétant....
  2. mais en cheque cest 'pire Rev131: May 8 - May 26 '10 [For trouble viewing the images/movies on this page, go here] Cassini continues its extended tour of the Saturn system with the 18-day-long Rev131, the spacecraft's 132nd orbit around the Ringed Planet. Cassini begins Rev131 on May 8 at its farthest distance from Saturn, called apoapse. At this point, Cassini is 2.6 million kilometers (1.62 million miles) from Saturn's cloud tops. With Cassini still in an equatorial orbit, the spacecraft will perform the second of two encounters of Enceladus over the span of three weeks. Cassini will also fly by Saturn's largest moon, Titan, for the 69th time. Cassini's ISS camera starts its observations for Rev131 two days after apoapse by imaging Titan's trailing hemisphere from a distance of 2.88 million kilometers (1.79 million miles). This observation is part of a series of images taken to monitor clouds in Titan's lower atmosphere. On May 11, Cassini will acquire calibration images for its wide-angle camera (WAC). The camera will image the star Alpha Virginis (Spica) first using its IR5 filter, then with a series of filters. These images are intended to check the photometric response of the WAC at the shortest possible exposure times. Between May 12 and 14, ISS will acquire three observations of Saturn's outer large icy satellite, Iapetus. These observations will be distant imaging opportunities with Cassini between 1.55 million and 1.90 million kilometers (0.96 million and 1.18 million miles) away from the moon. This sequence will focus on Iapetus' sub-Saturn hemisphere. On May 17 and the early hours of May 18, Cassini will turn its cameras to Dione as ISS rides along with the Ultraviolet Imaging Spectrometer (UVIS) and the Composite Infrared Spectrometer (CIRS). The first observation, riding along with CIRS, will focus on a crescent Dione. The camera team is interested in searching for possible cryovolcanic plumes emanating from Dione's fresh tectonic fractures. This observation will be acquired from a distance of 500,000 kilometers (310,000 miles). The second observation will be taken while CIRS measures the temperature of the moon's surface as it passes into the shadow of Saturn. Late on May 17, Cassini also will take a series of distant images of Enceladus in order to gauge the level of plume activity over the moon's south polar region. These images will be taken from distances of 230,000 to 440,000 kilometers (143,000 to 273,000 miles) as Cassini closes in on the icy satellite. On May 18 at 08:31 UTC, Cassini will reach the periapse of Rev131, its closest point to Saturn in the orbit. At periapse, the spacecraft will be 150,000 kilometers (93,000 miles) above Saturn's cloud tops. A few hours before periapse, Cassini will fly by the icy moon Enceladus, passing 436 kilometers (271 miles) above the satellite's surface at 06:04 UTC. This is Cassini's 11th targeted encounter with Enceladus. Unlike the last flyby when Cassini's high-gain antenna was pointed at Earth for the entire encounter, precluding imaging and other remote sensing, this encounter is dedicated almost entirely to remote-sensing, though instruments like the Cosmic Dust Analyser (CDA) and the Ion and Neutral Mass Spectrometer (INMS) will be active during closest approach to detect plume particles. Cassini will approach Enceladus over its night side, allowing CIRS to measure the satellite's night time temperatures and for ISS to image the forward scattering particles of Enceladus' south polar plume. Shortly before closest approach, ISS will acquire six high-resolution images of Enceladus' south polar jets, similar to the spectacular sequence taken during Rev121. The last image of the observation will include a "Kodak moment" image opportunity as a crescent Titan and Saturn's rings pass through the field-of-view. Following closest approach, Cassini's ISS and Visual and Infrared Mapping Spectrometer (VIMS) will observe the sub-Saturn hemisphere of Enceladus. ISS will acquire two mosaics of the satellite during the outbound sequence. The first, ENCEL001, is a nine-frame mosaic that covers most of the leading hemisphere portion of the visible disk. This mosaic will have a resolution of 91 to 135 meters (298 to 443 feet) per pixel. The second mosaic is a four-frame mosaic that covers all of the visible surface of Enceladus. ISS also will ride along with CIRS and VIMS sequences, taking a number of polarized green filter images with the CIRS observation that wraps up the encounter. Cassini encounters Titan on May 20 at 03:24 UTC for the 69th time. This is one of the last encounters of the first extended mission, which ends on July 1, with two more encounters to come in June. The close approach distance for the encounter (known as T68) is 1,400 kilometers (4,636 miles). This flyby will allow imaging of the anti-Saturn hemisphere of Titan outbound to the encounter. This encounter also will boost Cassini's orbital inclination, bringing it out of the ring plane for the first time since January. For much of the inbound and outbound segments of the encounter, the CIRS team will control spacecraft pointing, or be "prime." CIRS will focus on measuring the composition of Titan's atmosphere and measuring its temperature at different altitudes. ISS has a pair of prime observations on approach to Titan when only a crescent will be visible along with a ring of upper atmospheric hazes. These images will focus on characterizing changes in these hazes as spring progresses in the north. ISS also will ride along with CIRS's observations before and after closest approach in order to track clouds. When Cassini is closest to Titan and for a few hours afterward, RADAR will acquire a Synthetic Aperture Radar (SAR) swath across the southern leading hemisphere. The day after the encounter, on May 21, ISS will acquire a four-frame mosaic of Titan's anti-Saturn hemisphere from a distance of 585,000 kilometers (364,000 miles). Combined with the data acquired riding along with CIRS during the flyby the day before and single frame observations taken over the next two days, this sequence will be used to track cloud movement across Titan as well as assess the change in Titan's weather pattern with the onset of northern spring and southern autumn. Two additional observations will wrap up Rev131. On May 22, ISS will image Iapetus and its surrounding space to search for dust in the moon's hill sphere, the region of space where Iapetus' gravitational pull dominates over Saturn's. In-falling dust from Saturn's small outer satellites is thought to have been the catalyst of the dark terrain region on Iapetus. Finally, on May 23, ISS will conduct a calibration of its cameras photometric response by imaging the star Vega using all of its filters in both cameras. On May 26, Cassini will reach apoapse on this orbit, bringing it to a close and starting Rev132. During Rev132, Cassini will fly by Titan once again as well as perform a pair of close, non-targeted encounters with Rhea and Tethys.
  3. Quelques images de DIONE (au mini. à 504 km, le plus proche depuis 2005 !!) : D = ? km 19970 km 24500 km N00152893 - 56700 km Et aussi, en passant : - JANUS (N00152954 - ~75000 km) - EPIMETHEUS
  4. Deux lunes pour une seule orbite article de C&E paru a cette occasion JL D'Auvergne Le 15 février 2010, la sonde Cassini a surpris le passage apparent d’Épiméthée (138 km) devant Janus (194 km) ; animation ci-contre. Ces deux petits satellites de Saturne sont situés presque sur la même trajectoire, puisqu’ils se disputent des orbites distantes de seulement 50 km. Une particularité due au fait que les deux corps sont a priori les fragments d’un satellite plus gros. Actuellement, Janus circule sur l’orbite la plus interne. Il est en passe de rattraper Épiméthée. Ce faisant, il va freiner légèrement celui-ci, le faisant passer sur une orbite légèrement plus proche de Saturne. Par effet inverse, Janus va être accéléré et s’éloigner faiblement de la planète. Par ce mécanisme étonnant, les deux satellites s’échangent leur orbite tous les 4 ans environ. Un tel rapprochement entre les deux corps a déjà été observé en 2006. l’animation complete (et fluide) http://photojournal.jpl.nasa.gov/archive/PIA08348.mov
  5. mimas 'étoile de la mort" Distance = 15800 km Distance = 19460 km Distance = 71464 km avec en AP Saturne
  6. Bonjour a tous le site va évoluer Dans le but de le rendre toujours plus ergonomique et facile nous allons installer un cloud pour que les avexiens aient une zone d’échange facile d’accès et d'emploi [navigation] nous allons également essayer d'enfin faire en sorte que les dossiers soient synchronisés avec le forum pour la gestion des utilisateurs le forum va évoluer sur la dernière version, Wordpress également, et notre hébergement va évoluer vers des versions plus modernes , nécessaires à la mise en place et la mise à jour des nos infras Tout ce que j’espère c'est que vous ne verrez pas (ou peu) la différence, signe que tout va bien Astronono c'est proposé de mener ce projet éminemment délicat et je l'assisterai du mieux que je pourrais dans cette perspective : astronono à désormais les droits admin sur l’hébergement , le forum et les dossiers (wordpress) vous pouvez mesurer certains de ces changements entre autres par sa couleur de pseudo sur le forum qui passe en violet
  7. frédogoto a répondu à un(e) sujet de frédogoto dans Café
  8. un troyen :
  9. full http://photojournal.jpl.nasa.gov/jpeg/PIA11133.jpg
  10. de neige rhea téthys Prométhée, le satellite "aspirateur " de l'anneau F la version couleur permet de bien se rendre compre de l'action des depot de debris neigeux sur l’astéroïde le même a 33Mm la même en couleur par JLD
  11. cette video présente le déroulement de la mission Apollo11 avec les commentaires d'origine et dans le rythme des astronautes ainsi que des opérateurs dans la salle de contrôle à Houston http://www.firstmenonthemoon.com/ en chèque c'est pire
  12. faire clic droit sur les carré noir et cliquez sur "lire" [flash=960,690]http://s3.amazonaws.com/ciclops_ir_2009/5970_13992_2.swf et [flash=960,690]http://s3.amazonaws.com/ciclops_ir_2009/5970_13991_2.swf
  13. vue plongeante
  14. sous tout les angles
  15. les faille d’Encelade vue de dessus a 2000km d'altitude et la encore... on se croirait chez nous !!! 1850 km et celle ci sur rhéa
  16. encore titan et saturne et les geysers vue de nettement plus prés et sous un angle différent
  17. traitement de l'image par J.L. d'Auvergne l'ombre de Titan Titan justement, a contre jour ( traitement JLD) photographié a 162 giga metre ! plus que la distance terre soleil et la composition finale et en couleur de l'equinoxe ne ratez pas la full : http://www.nasa.gov/images/content/388135main_PIA11667_full.jpg
  18. texte de BobMarsian sur AS Très surprenante la petite lune (moonlet in the text) entrevue dès le 5 août par alan du forum Unmmaned Spaceflight sur l'image N00139448 (dist. 296000 km) se retrouve quasi-officialisée à une position par rapport aux anneaux tout à fait inhabituelle , c'est à dire (si confirmation de l'orbite) carrément au sein de l'anneau B, en-deça de la Division de Cassini ! Et encore plus étonnant, sans qu'elle ne perturbe visiblement la structure de l'anneau (pas de "gap" créé) comme si celui-ci se refermait autour d'elle !!! Son ombre permet d'estimer son diamètre à 400 m si elle orbite bien dans le plan des anneaux. Souhaitons qu'elle puisse être réobservée sinon, elle restera anecdotique comme pas mal d'autres jamais revues. les anneaux deviennent très sombre avec l’équinoxe. les poses s'allongent et du coup on voit les étoiles au travers
  19. de plus en plus applati mais la on commence a voir des structure assez intéressantes et la encore. dommage que la compression JPG soie si forte
  20. pour les images ci dessous faire un clic droit sur l'image et cliquez sur "lire" [flash=999,750]http://s3.amazonaws.com/ciclops_ir_2009/5591_12920_2.swf [flash=870,1000]http://s3.amazonaws.com/ciclops_ir_2009/5623_13086_2.swf [flash=1000,405]http://s3.amazonaws.com/ciclops_ir_2009/5617_13085_2.swf [flash=700,700]http://s3.amazonaws.com/ciclops_ir_2009/5654_13025_2.swf
