Obiwan
  1. trop fort ce script. Téléchargé et déjà installé. J'ai hate de tester ça même si maintenant, j'utilise Maximdl encore pour quelques jours en version d'essai >
  2. Obiwan a répondu à un message dans un sujet dans Café
    Merci pour les corrections. Pour le bleu, je trouve que ça jure un peu à coté des rouge, jaune et orange. Il faudrait peut être rester dans le ton.
  3. Obiwan a répondu à un(e) sujet de jeff dans Café
    Excellent ce divertissement ou plutôt cette fiction et après ils veulent mettre un satellite en orbite
  4. en tout cas, pour la liaison avec PHD, il faut lire la section view help et lire à la page 17 : 4.5.4 Link to PHD Guiding PHD Guiding is the popular freeware guiding package by Stark Labs. With it, guiding can be as simple as “Push Here Dummy.” With the PHD Guiding dialog, you can establish a link to PHD Guiding so that the two packages can talk to each other. This gives you two powerful features. First, it lets you pause guiding during the download of your main image. Some cameras are sensitive to interruptions on the USB bus and if the guide camera shares the USB bus, the image quality can be degraded. The “Pause during download” option will let you enable this feature. The second feature is to enable “dithering” of the image’s location across frames. Between frames, Nebulosity can send a signal to PHD to tell it to move the “lock position” (the position of the crosshairs in PHD) by a small, random amount. Once PHD has moved the star and reestablished stable guiding in the new location, a signal is sent to Nebulosity to let it know it can continue with the next frame in the series. To do this, you must: 1. Have PHD 1.8.6 or later running and tell it to “Enable Server” in the Tools menu (PHD will remember if you last left the server on and restart it the next time you start PHD). If Windows asks you whether it’s OK to do this, tell it yes. 2. In Nebulosity’s PHD Guiding dialog, click on the “Connect” button. 3. In the dialog, tell it how much “dither” to send. The dither sent will be a random number of pixels in X and Y, scaled by the level you pull down here. In the lowest level, the random numbers will vary from -0.5 to 0.5 pixels and in the highest they will vary from -1.5 to 1.5 pixels in the guide frame. Since people typically guide at shorter focal lengths than they image at, this will usually have a much larger effect in your main images. 4. It may be worth changing the “Settle threshold”. This specifies how far off the star can be from the lock position before PHD sends the message that it has gotten the star back on target and it is OK to resume your series capture.
  5. Non désolé j'ai confondu avec MaximDL ou Prism que je n'ai plus car j'ai dépassé la période d'essai.
  6. Obiwan a répondu à un message dans un sujet dans Café
    Bonsoir Brice. Intéressant mais j'aurais préféré un fond des sujets plus foncé. comme celui sur lequel je suis en train d'écrire ce message. voir plus sombre même. mais bon c'est peut-être mes yeux qui sont fatigués. De plus, sur la partie gauche, les avatars apparaissent en bas. Certainement à cause de la largeur. le mien apparait comme il faut mais celui de pep apparait après son texte. il faudrait rajouter quelques pixels de plus en largeur. Je précise au cas où, que je suis sur mon Eeepc, tjs en 1024x600. Par contre, je trouve bizarre la couleur bleue des sujets principaux. D'avance merci. Sinon, très sobre et plutôt sympa.
  7. Salut. De mémoire, nebuloIty gère les séquences dans un onglet spécifique.
  8. Un tuto sur quoi, liaison avec Phd ou pour le traitement ?
    En ce moment il ne fait pas beau. Prends le temps de chercher, passes une annonce ds AS et sur WA, dans ciel et espace ... Et attends un peu. J'ai eu un contact en 2 semaines. Es-tu si pressé que ça ?
    Salut, Je prend le post en route. C'est presque dommage que tu es vendu ton Equinox 120 car avec le nouveau flatenner 4 (si rééllement x0.8, à vérifier), ca te faisait une lulu ouverte à 6 avec une bonne focale et avec la 383L+, ça passe à l'aise. Maintenant, pour ma part, j'en ai eu marre de chercher la bonne solution lulu + correcteur. Faut dire que j'ai pas mal évolué, et rapidement en fait. Avec le recul, je pense que j'ai été trop vite. Mais bon, on se refait pas. J'ai revendu mon matos, comme toi, et j'ai rajouter un billet derrière mais au moins je suis certain du résultat. J'ai trouvé ma FSQ pour 3000€ avec sa valise et quelques bagues en plus. Si je souhaite passer à plus grand en terme capteur, j'aurais jamais à me poser la question du vignetage ... La tranquillité, c'est cool. C'est sûr que pour ma 383L+ ça fait un peu too much mais j'ai aussi mon 5D qui me sert en mode pampa dark sky. Alors en patientant peut-être un peu plus logntemps, peut-être que le père noel sera gentil avec toi ? ... Je dit pas qu'il faut absolument passé à la FSQ mais c'est à y réfléchir, poser le pour et le contre.
    C'est peut être parce que tu n'as jamais voulu te lancer. Certes tu as peut-être 2 pieds gauche à la place des mains mais t'es pas si incompétent que tu le prétends ! Quand même ... Je n'ose pas y songer une seconde. Bon ok, si ça m'a juste traversé l'esprit mais juste une seconde alors ! Je crois que tu préfères simplement la solution de facilité. Ce que finalement j'apprécie aussi mais c'est tellement sympa de mettre les mains dans le camboui de temps en temps, n'est-ce pas ? N'était-ce pas une belle aventure l'astro'home ? Tu as su nous prouver après de nombreuses tentatives que tu savais tenir un marteau puis avec gentillesse et surtout avec prudence nous t'avons laissé la perceuse !!! Moment inoubliable n'est-ce pas ? Tu t'en souvient ? Formidable expérience qui a durée 2 minutes mais ça a été intense en émotions ! Allez va, lances toi, pas tout seul quand même on sait jamais !!! Sinon, je crois savoir que certains ont quelques notions, en soudure... Ca pourrait même faire l'objet d'un atelier ça en échange d'une petite information sur le traitement d'images. A bon entendeur ... Bon aller je plaisante, si tas besoin de moi, fais moi signe.
  12. Obiwan a répondu à un message dans un sujet dans Discussions générales
    J'ai hâte de voir ça sur la CG5 !
  13. Obiwan a répondu à un message dans un sujet dans Discussions générales
    Nous en avions longuement parlé avec Brice lorsque je voulais changé mon Equinox. Pour sûr, c'est du sérieux BORG. Encore faut-il trouver un importateur. A ce que je sais, il n'y a malheureusement aucun importateur français. C'est bien dommage. Ce qui m'avait donné des idées il y a quelques temps. :F
  14. Obiwan a répondu à un(e) sujet de Obiwan dans Café
    En plus d'Alzeimer, je vois plus très bien. J'ai confondu le 1 et le 5 sur mon clavier. Faut dire qu'ils sont juste à coté !
  15. merci. Avec ta permission je les rajoute à la liste principale.
  16. [edit Obiwan] Ce post sera tenu à jour par mes soins pour avoir une liste aussi complète que possible. Tout magasin n'ayant pas de site internet sera ajouté sur une seconde liste en bas de page. Ceci afin que vous puissiez revenir consulter ce post aussi souvent que vous le désirez. Je considère qu'un magasin qui a un site internet, il est possible de consulter leur marchandise et donc de passer commande, même par téléphone. Liste des magasins Astro qui vendent par internet : Astrolactée : http://www.astrolactee.fr AstroShop : http://www.astroshop.de/fr Astromeca : http://www.astromeca.fr : Realisation toute pièce mécanique pour astronomie amateur. Axis Emmanuel Mallard : http://www.axisinstruments.com Galiléo France : http://www.galileo.cc L'astronome : http://www.astronome.fr La Clef des Etoiles : http://www.laclefdesetoiles.com La maison de l’astronomie : http://www.maison-astronomie.net M42 Optic : http://www.m42optic.fr Medas : http://www.medas.fr Modern Astronomy (anglais) : http://www.modernastronomy.com Optique et Vision : http://www.ovision.com Optique Unterlinden : http://www.optique-unterlinden.net Orion Telescope : http://www.telescope.com/ Pierro Astro : http://www.pierro-astro.com Promo-optique : http://www.promo-optique.com Scopemania : http://www.scopemania.eu Star Telescope (anglais) : http://www.startelescopes.co.uk Telescope Service (Allemand et Anglais) : http://www.teleskop-express.de/shop/index.php?cat=c4_Instrumente.html Uranie : http://www.uranie-astronomie.fr
  17. Obiwan a posté un sujet dans Café
    Joyeux anniversaire Thibaut. 21 bougies, il y a encore de la place sur la gâteau !!
    Il vient de vendre sa 120/900 Equinox, je pense pas que ça serait pour reprendre pareil, quoique ... Je ne vois pas de 115x800 ni de 130x900 sur leur site : http://www.astro-professional.fr/ Sinon sur le site Optique et Vision j'ai vu ça : Lunette Televue NP101, 101mm f 5.4. Tube optique vendu avec: . Valise televue. . Colliers. . Adaptateur photo. . Réducteur de focale Televue 0.8x. Cette lunette a produit de superbes images du ciel profond visibles entre autres aux liens suivants: http://www.astrosurf.com/ubb/Forum3/HTML/022784.html http://astrosurf.com/ahp/accueil_astrophoto_cielprofond_nebuleuses_epeed_orion.htm http://astrosurf.com/ahp/accueil_astrophoto_cielprofond_nebuleuses_autourd_alnitak.htm http://astrosurf.com/ahp/accueil_astrophoto_cielprofond_nebuleuses_ic2118.htm Prix demandé : 3000 euros TTC.
  19. Obiwan a répondu à un(e) sujet de frédogoto dans Discussions générales
    C'est bien pour évité de me prendre les pieds dans les fils que je me suis fait mon BRA2 que j'assemble avec le hub USB et que je fixe sur la monture ! un peu comme ça : ou sinon je pose le tout juste sous la monture comme ici : Avec ce hub ça fonctione parfaitement bien avec ma Atik 383L+.
  20. Obiwan a répondu à un message dans un sujet dans Photographies - galerie
    Enfin un truc différent que le ciel profond ... Moi je la trouve plutôt sympa cette vidéo full Hd ! on entend le hululement de la chouette et le moteur de suivi de la monture, bref on à l'impression d'être dans la lunette J'adore. Pour le sujet à inclure, y'aurait peut-être un truc mais difficile à prévoir : le passage d'un avion ou mieux celui de l'ISS
  21. Obiwan a répondu à un message dans un sujet dans Photographies - galerie
    Salut. Moi, malade, ah bon. Peut-être si tu le dis. En fait, je pensais surtout au et 7nm baader, pas au 3nm, je suis pas sénil, enfin pas encore, heu enfin je crois. Mais bon comme tu les a déjà vendu, comme ça, c'est réglé.
  22. Obiwan a répondu à un message dans un sujet dans Photographies - galerie
    Perso, si tu sais pas quoi faire de ton baader, je suis preneur si en 1"1/4 !
  23. Obiwan a répondu à un message dans un sujet dans Photographies - galerie
    Intéressant mis je trouve qu'il atténue quand même pas mal les étoiles le 3nm, plus que le 5nm, même si le s/b est meilleur. En tout cas, pour le moment je me contente de mon 7nm.
  25. Obiwan a répondu à un message dans un sujet dans Discussions générales
    des photos bordel, mais qu'est-ce que tu fous !!!! on veut voir ce que ça donne ! T'as pas de backslash ?
