Comme ma lunette me donne des étoiles multicolores, je me console en traitant les champs larges capturés avec la Star Adventure.
Objectif 70mm ouvert à f3.5, 16 poses de 88 secondes autour de Deneb.
Voici le détail de la reduction astrometrique de l'image
=> avec les catalogues locaux et ligne de commande sur le Mac.
hugh⨕mopla:nebuleuse|● solve-field -O --scale-units dw -L 10 -H 40 --downsample 4 n.jpg
Reading input file 1 of 1: "n.jpg"...
jpegtopnm: WRITING PPM FILE
Read file stdin: 5166 x 3420 pixels x 1 color(s); maxval 255
Using 8-bit output
Extracting sources...
Downsampling by 4...
simplexy: found 1940 sources.
Solving...
Reading file "./n.axy"...
Field 1 did not solve (index index-4119.fits, field objects 1-10).
Field 1 did not solve (index index-4118.fits, field objects 1-10).
Field 1 did not solve (index index-4117.fits, field objects 1-10).
log-odds ratio 134.2 (1.91642e+58), 21 match, 0 conflict, 54 distractors, 31 index.
RA,Dec = (310.146,46.0193), pixel scale 12.164 arcsec/pix.
Hit/miss: Hit/miss: +++-++-+-+--+-+-+--+----+-----++-+--+-+----+----------+------------+------+(best)-------------------------
Field 1: solved with index index-4116.fits.
Field 1 solved: writing to file ./n.solved to indicate this.
Field: n.jpg
Field center: (RA,Dec) = (310.1, 46.02) deg.
Field center: (RA H:M:S, Dec D:M:S) = (20:40:34.680, +46:01:01.552).
Field size: 17.3492 x 11.5265 degrees
Field rotation angle: up is 87.8024 degrees E of N
Creating new FITS file "./n.new"...
Creating index object overlay plot...
Creating annotation plot...
Your field contains:
Part of the constellation Cygnus (Cyg)
The star 30Cyg
The star 31Cyg
The star 32Cyg
The star 34Cyg
The star 36Cyg
The star Sadr (γCyg)
The star 40Cyg
The star 43Cyg
The star ω1Cyg
The star ω2Cyg
The star Deneb (αCyg)
The star 51Cyg
The star 55Cyg
The star 56Cyg
The star 57Cyg
The star νCyg
The star 59Cyg
The star 60Cyg
The star ξCyg
The star 61Cyg
The star 63Cyg
IC 1318 / gamma Cyg nebula
IC 5068
IC 5070 / Pelican nebula
NGC 6997
NGC 7000 / North America nebula
NGC 7039
La full est ici: http://www.astrobin.com/full/248251/
trés joli résultat, par contre je trouve aussi que beaucoup d'étoiles sont très jaunes... une petite crrection colorimétrique et elle sera superbe ;-)
Il y a quelque chose qui cloche la dedans, j'y retourne immédiatement !
ah ? => Boris Vian - La java des bombes atomiques.
Bon, j'ai largement baissé la saturation des jaunes dans la nouvelle version. Les nebulosités sortent un peu plus rouge aussi.
c'est dommage car j'aimais bien ce coté orangé, mais les étoiles sont aussi plus naturelles.
Toujours sur astrobin les full.
Comme Xavier : j'aime beaucoup ce champ et la seconde version est mieux. ;)
